How to prevent PC Reviver from running at every startup
Discussions on PC Reviver
Postby RS_Admin » Wed Feb 12, 2014 2:52 am
If you would like to prevent PC Reviver from running every time you start your computer, please follow the steps given below:
1. Open "PC Reviver"
2. Click on the Cog icon on the top-right corner
3. Under the Startup and Schedule area
4. Click and turn off the green switch for the Run At Startup option
5. Click on Save
Does the program still run at every start up?
If Yes, please follow the steps below:
1. Go to Start > All Programs > Accessories > System Tools > Task Scheduler
2. Look for entries of PC Reviver and disable / delete them from the list.
You can now use PC Reviver at your convenience!
Return to PC Reviver
