ReviverSoft Maintenance Plan: Scan for Viruses and Spyware
Scan for Viruses and Spyware on your Windows PC
Maintenance: Scan for Viruses and Spyware
Recommended Frequency: Once Every Other Week
Estimated Time: 10 Minutes to Two Hours
You may have an antivirus and antispyware application installed already; you may not. Whether you have a security program on your PC, you should still run a full scan for viruses and spyware on a regular basis. Though quick scans can take a half hour or less, scheduling a comprehensive scan for overnight, while you’re not using your PC, is wise.
For more about viruses and spyware, and why having a scanner for them is important, along with our recommendations for such scanners, check this article.
If you’ve already got a virus, and need to know the steps to take to get rid of it, check this article instead.
This is part of ReviverSoft’s Twitter PC Maintenance Plan. Follow us on Twitter for your comprehensive plan to keep your PC running at its best.
Recommended by ReviverSoft
download now
PC Problems?
Take a FREE
Windows Registry scan
to find errors that can
cause PC problems.
our products
See all products →
subscribe to our newsletter
